I've been reading through the archives, and there seems to be a wealth of Force knowledge here.
Hope you guys can help me out.
Motor runs flawlessly at any speed but idle.
Problem - motor eventually stalls out after idling for 1-2 mins (not a fun way to troll )
- starts right back up
- sometimes the fuel bulb has to be pumped to get it to start back up
I've checked/replaced everything outside the motor related to the fuel system.
I am planning to put a new fuel filter in it.
While checking out the entire fuel system, I discovered I could force fuel out of the fuel bowl of the carb by pumping the bulb (where the fuel bowl meets the body of the carb). I assume a carb rebuild is in order. Little nervous, I have never tried to do one myself.
Any thoughts or words of encouragement for me???
