bravogolf
- Mar 15, 2011
- 14
My 1986 Force 125hp outboard is over-charging the battery. It is continuously charging above 16volts. Highest reading I have seen is 16.50 on my voltmeter. If I am at idle, it is at 13volts. The maintenance manual says my certain model does NOT have a regulator, but it has a rectifier. Is my rectifier bad?? How do I lower the charging voltage to normal. Is normal about 14.5volts? Plus how bad is this for the battery? Thank you!
