Hello,
I have a 1975 Chrylser 75hp that I am trying to figure out Tilt/Trim wiring.
This is not original to the boat so I'm pretty much on my own.
My tilt motor has THREE wires. I have wired directly to the battery but wires
get hot. ALSO, when operating it smokes the ground wire on the Outboard
Ground wire attached to the Outboard solenoid.
I've searched this site with not much luck but I basically have two questions.
-It would seem I need to use either relays or solenoid for my Tilt/Trim to stop
the heating of the wires but WHICH is better or WHAT's the difference btwn
solenoid vs relay...also would I need One or Two?
-WHY would direct connection smoke the wire on the outboard??? Will the installation
of solenoid or relay stop this? To test run my motor I had to use separate batteries
but would like to just use one but obviously I don't want the tilt/trim to burn up
my outboard.
THANKS for the help!!!
Travis
my outboard.
Travis
