My 1997 40 HP Tracker s/n OE276051 will not run at idle/wake speed. Cranks ok, idles, and accelerates fine at home on the hose. In the water, it cranks and runs fine at wake speed on the way out. Throttles up fine, and runs well at WOT. However, when coming in to load at the ramp, it dies after long idle/wake speed. I took it out today to try and fine-adjust the idle screw, and noticed that it runs ok (better) with crowl off. When I put the cover back on, it will slowly start running rough. Seems to be a lot of smoke and shaking when it is about to die... but remove the cover, it improves and stays running.
I have replaced the diaphragm, cleaned the carb, and set the idle at 1.5 turns, then 1.25 turns, then 1.75 turns. Loosened and tighten the white nylon screw adjacent the idle needle, but nothing improves or worsens the condition. Read through alot of forums, but not found the answer - can someone point me in the right direction before I take it to the shop?
