Re: 55 Chrysler Steering Issues
What is your steering setup? Does the steering cable run into the tube on the motor? if so, have you tried greasing it? I have an old 35hp that I had to turn all the way until the rod was out of the tube, then grease the rod. I then worked it back and forth for quite a while, adding more lube as I went. It eventually got alot better, but you should have two grease points right there above the tube. I would also check for binding anywhere it can, ie... the steering joint, a kinked steering line etc. Also lube the kingpin that the engine rotates on, there are grease fittings there also. Is there a nut on the steering column that you can tighten to keep the wheel from moving? Mine has one, and I occasionally forget to loosen it after trailering. Hope that helps.
