Re: 88 force 85 horse tilt trim check valve missing
the pump assembly is motor + valve body. The motor includes reservoir. The valve body is the thing on bottom where tubes are attached. Bleed down is caused by valve body. There is no manual release valve on 1988 trim. However, the valve body is made from universal casting and people often call the check valve a manual release valve. It isn't though.
you can get a new valve body for $130-$250. The different amounts you pay will be for different boxes and stickers. There is only one place making them and they are all the same. The new ones are made in Asia from softer metals and won't hold up under big horsepower as well as original. However, 85HP isn't that big and I think a new one would not have any problems lasting fairly long time.
rebuild is cheaper and better quality but not as fast to get boat back on water.
$300 for a used vavle body? I want some of whatever he's been smoking.
