Thanks in advance for any help
I just bought a 1994 Force 40HP 2 cylinder power trim/tilt, this unit has a 8 pin female plug on the motor. I have the cable controls with trim/tilt button but the unit had a dash mounted ignition switch separate from the controls and the owner kept it in his boat. I need to know how to wire a ignition switch into the 8 pin female connector on the motor, I do not have the male 8 pin plug so I may have to splice in the wires. Does anyone have a diagram with wire colors or know where I can get one?
Thanks again
Thanks again
