erosenwinkel
- Apr 22, 2011
- 130
I am really struggling with this ignition switch, I have asked everyone I know and I am not getting very far. I have installed the new switch, in what I believe is exactly the same manner as the old one. It is a 3 position with push to choke. Off, Run, Start and push to choke. The rear of the switch has 6 terminals as did the old one. After I reconnected the positive terminal of the battery. I turned the key to the run position (not all the way over to the start position) and the engine turned over. That is as far as I got. I know I have a couple of the wires switched around but I don't want to play Russian Roulette and smoke something important. 1984 Bayliner Capri with Force 125 hp (1258x5a). New switch is a Seasense #50031154. Thanks.
