So I installed a new 6 pole ignition switch but now have a drain on the battery. On the motor is has a list of the wire colors. It is as follows:
Start-yellow
Generator-purple
Tach- white
Choke-green
Heat-orange
Battery-red
Ignition-blue
Ground-black
I have the switch wired with
S-yellow
C-green
B-red
A-blue
Where should the purple, white and orange wires go? There are 2 terminals marked M on the switch.
Start-yellow
Generator-purple
Tach- white
Choke-green
Heat-orange
Battery-red
Ignition-blue
Ground-black
S-yellow
C-green
B-red
A-blue
