the engine idles perfectly in nuetral but when your shifting in and out of reverse like when your docking or loading on the trailer there seems to be no fine throttle control. also with the cover off when you engage forward you have to move the trottle almost halfway through its range of movement before you can see any movement in the carb linkage. Is this normal and if not whats wrong and how do i fix it cause im tired of bashing my boat into my trailer.
