Hello,
Ive got an old force engine which has been a pain in my ***** since day one. Anyways now after checking the fuel system and ignition system the motor will bog down at wot. It starts fine, idles fine, and will run fine at low rpm. when the throttle gets to 3/4 to full it just doesn't make the rpm's it used to. Im lucky if I can get it to make 3500. While running it will sound like it wants to rev up in small spurts and the tach will jump a little. I took the cover off and found it was dripping fuel out of the top carb while running at full throttle. also i installed brand new plugs which didnt fix much. it sounds like im getting too much fuel? Any suggestions?
Thanks!
Thanks!
