Re: Trouble starting 78 Chrysler outboard
Couple of things. First; welcome to iboats. Second; it's always best to run a compression check, then spark test and then fuel on any "new to you outboard" before even getting to the point of starting. As for your Chrysler, I'm sure one of the real Chrysler pros will chime in, but in the mean time, I had a Chrysler 50 so I'll give it a try. Your ignition key should be able to "push in" while turning. If so,
that's the auto choke. In neutral, your controls should have a "warm up" lever that allows you to get the fuel flowing. Pull out the warm up lever and push the throttle forward (it won't go as far as if you were running and in gear), push in on the choke while turning the key to start. Always make sure your fuel bulb is tight by giving it a few pumps before you start it. If this doesn't work, then I'd post the results of the Compression/Spark/Fuel tests and wait for the "pros" (like Frank)
