97 Force 120 Water Temp Gauge Sender/Sensor Location
anple
Hello Everyone,
I'd like to install a Water Temp Gauge for my motor. I found a location near the T-stat that I thought I could insert the sender / sensor. Can someone tell me if I could do that? What gauge kit and specifications would you recommend? Many thanks in advance! - Anthony :confused:
Josh P
Re: 97 Force 120 Water Temp Gauge Sender/Sensor Location
thats the spot... i am going to install a temp gauge to when i get my boat done. i plan on using a digital read out one. because the scale on the gauge starts at 70 degrees F and reads to 250F. These outboards dont get very warm maybe 140, so on a standard gauge it would never move much if you had one..
http://www.summitracing.com/parts/CYB-A020E060N/
thats the one im looking at.. i know its an auto gauge but its sealed
anple
Thank you, Josh! Will the Sender perfectly fit the spot diameter or modification is needed? Thx.
