Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Drive shaft upprer? seal and retainer ring 1998 75 HP Force by Mercury
This topic is closed.
  • Drive shaft upprer? seal and retainer ring 1998 75 HP Force by Mercury
    OK, so pictured here is the exploded view of the top end of my drive shaft for the 1998 75 HP Force.
    The diagram shows the seal and retainer ring.
    Click image for larger version
    My questions are as follows....
    a) how important are they, looks like they would keep a bunch of stuff out of the power head????????
    b) Looks like the seal goes upright with the fat end up, i found it wedged in the drive shaft housing with no retainer ring, shown in picture below
    c) I cant order that retainer, unless thats the ring jammed up inside ( which I have not tried yet to retrieve) the drive shaft housing, pictured above. Can I order a retainer ring for a different engine/year/model or something.
    and...
    d) last but not least, if and whenever I can get my hands on a retainer ring, how far up or down the shaft do I secure the seal and retainer ring??????
    1970 17' Runabout
    1998 Mercury/Force 75 HP
    Barnegat Bay, NJ
    sigpic
    Re: Drive shaft upprer? seal and retainer ring 1998 75 HP Force by Mercury
    Loking further at these diagrams on crowley marine
    http://www.crowleymarine.com/mercury...ts/2534_19.cfm
    These dont look like the right parts, the seal looks a lot different and there is no visible nut ( # 7) on the above diagram
    It looks like all these parts go on top of it.
    So really my question is, where did this part come from???????????Click image for larger version
    1970 17' Runabout
    Barnegat Bay, NJ
    sigpic
    • #3
      well I replaced the seal in the prop shaft shift shaft and found where the black seal goes on the drive shaft found a retainer ring in the drive shaft housing right below where the red circle is in the above image ....
      and then put the water pump gasket in place tightened it down the housing and bolted the lower unit back on.
      Took for quick 5-10 min. Ride. Everything worked great.
      1970 17' Runabout
      Barnegat Bay, NJ
      sigpic
      • #4
        Wow, can't believe you got no responses from the first 2 posts.
        But glad you got her all figured out.
        Thanks for reporting the results, it will help someone in the future.
        Medford, WI
        • #5
          I'm in pretty much the same boat as the first guy except the owner before me I'm guessing put it together the last time without that retainer ring I found the seal chewed up exactly like he said but I can not find the retainer is there anyway around it or another place to buy one??
          • #6
            They don't like it when you open up posts that are old.
            Start a new one and use the info from that post.
            Always include the year, model and serial# if you have it.
            ​The seal and retainer, still available $14 42461 A1
            That is if your motor is a later year Force with the Mercury lower unit.
            You can add a signature to your posts and include the info on your boat and motor.
            Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
            ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
            In Scenic , Beautiful San Sebastian by the sea Florida
            88 Bayliner 21CC 2001 Mercury 225 HP EFI
            • #7
              Closed.
              BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
              Please, no PM's (Private Messages) regarding boat/engine problems.
              That is what the forums are for.
              Only forum/moderator issues will be answered in PM's.
