Force 125 HP 1984 Bad Spark Plug Caps
labawg
Are these zero ohms and if so are the NGK LZFH good enough?
Best Regards
labawg
Re: Force 125 HP 1984 Bad Spark Plug Caps
Found out yes zero ohms so they will work.
labawg
Do not order this NGK part number unless your spark plugs have a removable terminal nut!!!!! The best ones I have found (for solid terminal nuts) are the Champion PRO0U. Solid Brass inside and screws on to the spark plus wire. Did cure a slight miss I had and seals really well around the wire and spark plug. the only problem is they cost $5.00 apiece.:(
Sorry
