Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1998 40 hp Force outboard (Mercury) starting problems
  • 1998 40 hp Force outboard (Mercury) starting problems
    i bought my boat about three months ago and it was running fine until i ran into a starting problem. About three weeks ago i was out on the water and i began to crank my boat and all i heard was a clicking noise from the motor, it finally cranked up. Now most of the time when i crank it all i hear is that clicking noise with an occasional crank every now and then. The guy i bought the boat from said he had replaced the solenoid this past summer. What could be the problem?
    Re: 1998 40 hp Force outboard (Mercury) starting problems
    Could be bad battery cables/connections, or a bad battery. Undo all the battery cable connections (both positive and negative cables) and clean them. See if that helps. If not, get the battery tested.
    • #3
      Sorry I forgot to mention, I tried hooking it up to a different battery and it still wouldn't work, but I guess it could still be bad cables.
      • #4
        Sounds like a bad solenoid.Or the connections are loose.Possibly the starter.
        Test light.The solenoid should have power across both lugs when the key is activated.
        No power on both(bad solenoid).Power on both(bad starter).J
        Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
        ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
        In Scenic , Beautiful San Sebastian by the sea Florida
        88 Bayliner 21CC 2001 Mercury 225 HP EFI
        • #5
          Update on the starting problem. I bypassed the solenoid to crank the motor and it cranked right up. So im guessing i need to buy another solenoid. My next questions is this, do i need to buy one that is specifically for this motor or could i just pick one up at a autozone store? thanks
          • #6
            By bypassing the solenoid did you use jumper cables directly from the battery to the starter or did you use the original wiring and bridge past the solenoid? If you went from the starter to the battery you could still have wiring problems. If you bridged past the solenoid then the main wiring is OK but you may be getting a voltage drop on the switch circuit to the solenoid or the solenoid itselfis no good. You could supply 12 volts to the switch side of the solenoid circuit to test this.
            If you jumped from the battery to the starter any of the wires in the starter circuit could be the problem.
            Check all your connections first before you start replacing things. Negative cable where it attaches to the engine block can corrode. You may also have a voltage drop on the switch circuit to the solenoid. Cable ends and cables themselves can corrode. Replacing the solenoid will not fix these problems. Use a multimeter set to OHMS. You should have very little resistance in the wires.
            Any similar rating solenoid should do the job if you find it is the solinoid.
            Good Luck
            • #7
              Ok, I did bridge past the solenoid so how exactly do I check the voltage on the switch circuit to the solenoid. And if this is the problem how can it be fixed. Thanks
              • #8
                You can test it by running power to the switch side of the solenoid. If the solenoid works the problem is likely to be a voltage drop. You could use jumper leads directly from the battery or take power from the heavy positive battery terminal lug on the solenoid & bridge it to the small positive switch circuit lug.
                The other way is to test how many amps are in the positive switch side of the starter circuit. (NOT THE STARTER SIDE OF THE SOLENOID) . Iím not sure how many amps the solenoid need to work. Hopefully someone else will know. I would expect about 3 amps to 5 amps. Check the earth wire to the solenoid has a good grounded as well.
                If this is your problem. Three ways of fixing it.
                Repair the old wire. eg find a corroded connection, switch or wire.
                Run a new wire from the solenoid to the ignition switch & back.
                Fit a relay next to the solenoid to supply power using the old wiring. This is the quickest method. These relays require very little current to operate so even a weak signal from the switch will work. I can show you a diagram to help.
                Good Luck
                • #9
                  If it's not too much trouble a diagram would be greatly appreciated. Thanks a lot for the help.
                  • #10
                    Bridge between the + from the battery to the + switch wire. You can do this with a piece of metal or make up a switch wire. Make sure the ground wire has a good earth.
                    I have a switch wire that I use to work the starter when timing the motor. It is just a length of wire with alligator clips each end and a push button that needs to be held in for it to work.
                    If the starter works by this method its you wiring that is the problem. If not its your solenoid.
                    Hope this makes sense.
                    • #11
                      ok, i bridged between the + from the battery to the + switch and all i got was a clicking noise again so i guess its a bad solenoid. I really appreciate all the help, it made perfect sense and the diagram was helpful as well. Once i get a new solenoid i will update the situation. thanks again for the help.
                      • #12
                        this is good stuff. I'm having similar problems and this helps ALOT.
                        • #13
                          • #14
                            Balford2. If the earth wire is good it would seem you have a faulty solenoid. You may have already checked this but you can run a jumper wire from the negative battery terminal to the negative switch lug on the solenoid(Just to be 100% sure its not a bad earth). Bridge the same terminals as you just tested. If this doesnít work it has to be your solenoid.
                            rgmatt.. Balford2 has run some other tests to isolate his problem to the solenoid.
                            If you are having starter problems you will need to run through some simple tests to track down the problem. Iíll be happy to help you but it would be much easier if you would start another thread. Information on what motor you have, the problem and what you have tried so far are really helpful. It can get a bit confusing sorting out two issues in the one thread. But it is nice to know this thread has helped.
                            Cheers
                            Dean
                            • #15
                              Cheers
                              Dean
