buzzbomber
- Apr 3, 2011
- 45
Bought my first boat, has a 120 force on it.
Having issues with temp alarm at idle after about 2-3 minutes temp alarm sounds. If I put it in neutral and give it some gas temp alarm will go away pretty quickly or if I just throw it in gear and go faster temp alarm goes away quickly.
It alarmed twice at idle then for the rest of the day boat ran great but I avoided staying in idle for more than a minute.
I'm new to boating and trying to figure out the issue, since looking it up I should have killed the engine quickly. But I ran the boat for about 4-5 hours afterwords and it ran great so hope I didnt do any real damage.
From what I read it could be the impeller, the housing, or thermostat? does that sound right and Is there anything else I should replace or check?
Trying not to hose the engine, it runs great at speed and in reverse, just idle makes it heat up.
appreciate any advice.
