Hello All,
I believe this is my first post on this forum, but I really need someone to help me out. I am still a beginner when it comes to boat ownership, however, I know a little jargon; but please keep it light (or at least be patient, if I ask for a definition). Also, please be gentle as I am inevitably going to ask a dumb question eventually, if not in this post
I have a Maxum 1800XR with a 1995 120 Force Outboard. I have had issues with this boat from day one, in fact, I'll bet I have spent more time out in the driveway working on it or being towed in on it more than I have actually had it on the water. But I digress, I will spare you all the details not pertaining to my question; unless you think it would help to answer the question, if this is the case please feel free to ask.
After battling several issues with this boat (some electrical but mainly starting and running) The last time I had it out, when I tried to start the boat it wouldn't turn the flywheel (unless you count spinning it in 1/4 turn increments) it sounded like a gallop, but wouldn't start. I took it in to my boat mechanic and after looking it over and giving a compression test, he said that one of the cylinders were scored, thus locking up the piston. He advised me not to fix it, but to sell it for whatever I could get out of it with a scored cylinder wall, and buy another boat.
However, I used to work in a machine shop a few years back and know the owner of it quite well. So, I decided to take the power-head off and take it to the machine shop, do the work myself and pay the owner or the use of his equipment. So, I bought a manual for the motor (ordered from this site, if I am not mistaken) and went to work taking off the powerhead.
Sure enough when I removed the head, cylinder #3 (I say three tentatively, it was the third cylinder if you count down from the top) was definitely scored. Everything was going smooth with the breakdown until the end; where you actually take the powerhead off. I should note that I am attempting to take the powerhead off while the motor is still attached to the boat (I don't know if that makes a difference, but I have nowhere to take it off otherwise, because I have to work on it a weekend at a time.)
Anyway, I followed the manual's instructions to a tee (it has proven very helpful) all the way to the last step where it states that I need to remove the bolts that hold the powerhead on. I have removed two, but the manual says there is 6. This is where I have hit a snag. There are 2 torque head bolts threaded upward (perspective is motor upright) from the mount into the block. I can't figure out how to get these bolts out, as they are on the bottom of the powerhead and the space is restricted by the flange that the cowl sits on (best I know how to describe it). It would literally take an Allen wrench shaped like a "J" to get to them. With the limited space even that is debatable. There are 2 more torque head bolts on the outside of the the flange (casing that the cowl sits on; please forgive my stupidity) casing just above what looks like the steering linkage; however, there are two steel (or maybe cast iron) pieces that block these bolts.
Am I after the wrong bolts? I even took off the cover that goes around where the lower unit meets the powerhead and removed those nuts, to no avail.I can't help but think those 4 bolts are what has to come out, but how do I get to them? Is there a trick that I am unaware of? Or am I just stupid? :facepalm: I can't get this to the machine shop unless I get it off, and I would like to rebuild it (if it can be) before summer arrives, because right now all I have is a $4500 Driveway Ornament.
I apologize for the lengthiness of this post, but I could really use some advice. If I am making a boneheaded mistake, please be gentle; like I said earlier I am new. I have heard that the two happiest days of a man's life was the day he bought his boat and the day he sells it. I am starting to believe that. :facepalm: Anyway, thanks in advance for any advice you can give me. I can't really reciprocate boat advice for boat advice, but I can answer computer questions if you have any.
