capnstabbin
- Mar 17, 2010
- 120
Does any one know how to time a 1998 Mercury Force "Tracker" 75 HP?
I have the same motor & they are great when tuned but a pig when out of tune. They are easy to adjust as they only have one carbie but it is always a compromise as the top cylinder runs leaner than the bottom. I always err just on the rich side when adjusting the mixture to ensure the top cylinder is not running lean. If the idle speed is set too low the motor stalls frequently.
The idle/mixture adjustment is the last thing I do when servicing the motor. Have already checked compression, fuel, spark, decarbed, cleaned carbie, checked float level and timed the engine.
Timing link to FAQ section Joe Reeves WOT timing procedure?/ 228183
Link and Sync by Frank Acampora. Better than the manual. I set the timing on the water. Not sure whether Frank is talking about static timing in this artic
Synchronizing Carbs and timing on a 75-150 Chrysler or early Force?/ 431021
Good Luck
