Dan Mckenna
- Mar 18, 2011
- 2
Hello I am a newbie with a fairly decent mechanical background. I have a 96 or 97 force 75 hp on my 20 foot pontoon that is slipping or missing when warm. I just replaced the plugs water pump and housing. there was some water in the gear oil but no sign of metal shavings. I have checked with different props and there is no prop slippage and the cavitation plate sits about 10 inches under water so i do not believe it is prop slippage or it coming out of the water. So basically when I am driving it normally at full throttle (its a pontoon) I have noticed a slip or a miss. the motor runs strong and smooth but it intermitadely feels like the motor misses or slips and tilts back and then comes back against the boat and makes a slight jolt and kind of a dong sound. I have noticed some fuel coming from the edge of the bowl on the carb. Do you think it could be losing fuel for a second? possibly a coil going bad? or a lower unit problem? i am kind of at a loss and looking for any help in taking the next step in diagnosing it.
Thanks for any help,
Dan
Dan
