Hi all,
New to boating and to forum. Recently purchased a 1994 Bayliner 1600 w/ Force 70hp. Taken it out a couple of times-no problems. Took it out this past weekend and overheat warning alarm sounded. Noticed a steady stream of water thru "pee-hole" and motor felt relatively cool. Seemed to happen after trolling for about 15-20 minutes. Pulled boat out and noticed oil leaking from prop exhaust. Did overheat warning test-ok. Are problems related or am I dealing with two different issues? Where do I go from here?
Thank you in advance!
