Re: Force 70hp 1992 model - electrical
It would probably help to define "broke down". Did it overheat? Make a
loud rattling noise and hiss? What happened and how did it happen?
Oh, and a heads up, you're gonna get the following advice, so it would help
these guys a bunch if you went ahead and figured this out;
1)Do a compression test 1st
2)Then do a spark test
3)Then check fuel system (complete)
And, then, post your results. Lots of good people on here with tons of
answers they just need to know the question. It'll be found and you'll be
better equipped for anything down the road, as well. Good luck.
