I recently purchased a 97" pontoon with a Force 120 outboard. I want to change the spark plugs, and looked at the ones that are currently in it. They are NGK BUZHW. I went on the search for this plug locally, but with no success. I was able to find them on the net, but they are around 11 bucks a piece. Wow, that is outrageous! I went back to the net and looked for cross reference on plug brands. The BUZHW crosses over to the following:
NGK STK: 2147
AC Delco: M40FFX
Autolite: 2852
Bosch P/N: WEA
Champion P/N: QL76V
Champion STK: 898
Denso P/N: SF-50
Denso STK: 6001
GM OEM NR: 5613574
Splitfire: SM264D
NGK TYPE: MARINE
Thread size: 14MM
Hex size: 0,81
Reach: 0,5
Seat type: GASKET
Projected tip: SURFACE
Now, armed with information, I called my local NAPA store and they came up with the AC Delco M40FFX which cost me a whopping 2 bucks each. This is my delimma! The M40FFX have electrodes, where the BUZHW are flat. Can I use these plugs? If so, what is the gap? (plugs are old stock, obviously, so the tips are bent and need to be re-gapped). I have searched everywhere and can not get the gap. Does anyone know?
Thanks,
Gone4two
NGK STK: 2147
AC Delco: M40FFX
Autolite: 2852
Bosch P/N: WEA
Champion P/N: QL76V
Champion STK: 898
Denso P/N: SF-50
Denso STK: 6001
GM OEM NR: 5613574
Splitfire: SM264D
NGK TYPE: MARINE
Thread size: 14MM
Hex size: 0,81
Reach: 0,5
Seat type: GASKET
Thanks,
Gone4two
