I came into a 1988 Bayliner Capri with a 1988 Force 125 Motor on it. The control needed to be replaced as well as 1 cable. I took the cables off the motor (still attached to the control) to the marina to order replacement control and cable. I purchased a Teleflex SL3 control module (sidemounted) http://www.teleflexmorse-eu.com/library/instructionmanuals/SL-3.pdf
I hooked up the cables to the engine but am having trouble hooking it up to the control module. I have attached pictures showing different positions and need help figuring out what is reverse, neutral, and forward and what is open throttle and closed throttle. This is my first boat and all help is needed.
Thanks Matt
Pictures below are what I am working with.
http://www.flickr.com/photos/24020690@N07/4964895845/
[/URL][URL="http://www.flickr.com/photos/24020690@N07/4965494676/"]http://www.flickr.com/photos/24020690@N07/4965494676/[/URL]
[URL="http://www.flickr.com/photos/24020690@N07/4965495320/"]http://www.flickr.com/photos/24020690@N07/4965495320/[/URL]
[URL="http://www.flickr.com/photos/24020690@N07/4964894355/"]http://www.flickr.com/photos/24020690@N07/4964894355/[/URL]
[URL="http://www.flickr.com/photos/24020690@N07/4965496200/"]http://www.flickr.com/photos/24020690@N07/4965496200/[/URL]
[URL="http://www.flickr.com/photos/24020690@N07/4965496634/"]http://www.flickr.com/photos/24020690@N07/4965496634/[/URL]
Thanks Matt
