Re: Location of neutral safety switch, 85 hp 1989
Jerry, thanks for the feedback. What is the best way to test whether the switch is working properly? I assume it's an electrical component as opposed to a mechanical device? Can I take it off and clean/adjust? Or does it either work or not work? I'm having issues restarting after stopping or stalling... sometimes turning key doesn't turn engine over and choke doesn't move. But, if I shift into forward, then back to neutral, I get choke and the motor turns over... Thanks very much..
