Walleye Vision
- Jul 20, 2010
- 1
I just put a new water pump kit in my motor, after I got it back together I noticed that I cant seem to find neutral. Im completely lost at this point I marked the pin on the linkage located on the lower unit and everything. If you have any advice at all I will take it ( even if your advice is take it to a mechanic) Thnk you in advance for your help.
