Hey all, I am a newbie as you can see. I am going through the force owner frustration syndrome. I have been lurking for a while, I must compliment you folks on your expertise. O.K. Enough shmoozing. Here is the situation: '89 force mod. 507Y9B. Have owned her for 2 years, never a problem until last trip out. The motor ran great as usual. At the end of the day I putted back to the launch through a no wake zone for about 15 min. Shut the motor off to get truck/trailer. Went to load boat - no start!! I replaced Spark plugs (ngk buhw-2). Nothing. I am getting fuel (50:1). Spent the last two days checking wire connections throughout the setup. All are in good order, clean and tight. Kill switch, stop wires...I am sure that it is a fire problem. When I did the stop wire test with a volt meter CD wire to terminal I had 1.7 -2.1 volts when bumping the starter. Sorry for being so long, just wanted to get as much info out as possible.
Thanks in advance for any help, shore bound in Wa.
