Nitefire36
- Jul 7, 2010
- 3
I have a 1988 force 50 hp model 507x8b .The ignition switch fell apart so I bought a new switch.When i wired the new switch up the bottom spark plug gets no spark,I took the white mag wire off and exchanged it with the blue mag on the engine
too see if the bottom plug would get spark, and the still will not get no spark,With the blue wire now on top ,I disconnected it back off and the motor starts.
Except it starts with white mag wire on bottom ( blue mag disconnected from key and motor ) and starts on top spark plug only Still even though its still hooked to the lower mag for bottom spark plug .
Does Anyone have any thoughts on what could cause this.So i can get both plugs back to fireing right????
