camawelander
- Jun 4, 2008
- 34
Hi,
My Problem:
Motor (89 force 35) ran great yesterday. Started up nicely 30 - 40 times fishing around the lake. On the last 2 starts I noticed some hesitation from the "starter". Normally I turn the ignition and the starter will spin the flywheel until the motor starts. Sounds perfect. These last few times the starter would turn the flywheel, and then hesitate half a second, and then the motor would finally fire up. Felt like maybe a low battery.....So I charged the battery to full.
Now I turn the ignition to start and I get nothing. If I push the key in for choke, the carb will flap closed, so I know that I am getting power to the system. I have checked and cleaned all of my electrical connections.
(note-the motor is well taken care of, very clean- new impeller-new plugs- always fresh fuel, the flywheel will turn the prop when engaged so there has been no overheat seizure...)
My guess is the starter solenoid, any other guesses?
Does anyone have a part number / good source that I can cross reference what I have found online so far?
Thanks
My Problem:
Thanks
