Hi I am new to this forum. Hopefully someone can help me out. I replace the impeller on the LU. and now shifting is way out of norm. When trying to replace lower unit I had problems aligning shift spline. I turned lower unit spline to line up with upper unit and now totally out of sync. How do I put back to normal. I ran engine and shifted to neutral (although not in correct position) lowered lower unit and put gear shift in neutral and reinstalled lower unit. Still not in correct position. Any and all help will be greatly appreciated.
