ddelamerced
- May 17, 2010
- 6
Hey just reinstalled a used lower and did maintenance, everything went fine but is having issues shifting or making a adjustment on the shift cam. When I got it out on the water neutral seem to engage the motor forward and it wasnt idling still. When I shift forward it will throttle the boat forward but when I shift into reverse it also makes the boat go forward. How do I adjust or fix this issue? Any tips or tricks in adjusting the lower unit shift cam with the upper? or any ideas on how I get neutral to be neutral and reverse go reverse?
