I have a 1980 75 horse Chrysler on my new boat, and the only pages missing from my engine manual are those on the starting procedures, go figure! I just bought this boat last week, replaced the bad starter, cleaned all battery cable connections, fresh gas, new plugs, etc.
I pumped the primer bulb up until there was pressure, set the throttle to neutral warm up, and cranked it over with the chokes closed. It will fire and run for about 1/2 a second, or so occasionally. usually, once the engine fires once, it kicks the starter drive off the flywheel and stops, while the starter just turns in place. It will not stay up if it fires. I can't keep it engaged long enough to allow a good start/restart. Suggestions? Is this the correct starting procedure?
Also, after I pump up the prime and crank it and it fires a few times, the primer bulb is soft again. I tried cranking the engine over without the outlet line to the carbs connected to the fuel pump, and nothing comes out. All the gaskets and such have been replaced in the pump, screen is clear, and if you remove it and apply a vacuum to the vacuum line it pumps fine. Should it be pumping when the engine is spinning off the starter?
Thanks!
Thanks!
