jason32038
- May 25, 2009
- 555
I have a heavily damaged cylinder on the 86' force. Picked up an 88' powerhead from the marina and was wondering if there was much difference between the stator and trigger between those years. The 86' has terminal connections and the 88' has plug in style connectors. Both stators have the same number of wires but the 88' has some larger wires. My question is...can I cut the connectors off of the newer engine and wire them to the terminal or not? I did some research on parts and it looks like these blocks use most of the same part numbers. Also...I didnt know where to find the serial numbers but I found these numbers under the flywheel on the block... Thanks.
86' - 498150
88' - 498150-1
86' - 498150
88' - 498150-1
