nathanhooper
- Apr 21, 2010
- 176
So here is a slight continuation, but new subject in the same. Took the pistons out last night. When removing the first one, top, I thought that I might be wasting my time doing this. It was in real good shape. But then again this is my limited knowledge speaking. This would be why I am bringing it to the board for examination.
The middle piston, the one with the worst cylinder, was messed up pretty good. When I pulled it I was glad I was doing this after all. The rings are stuck on it from the metal on the edge of the ring grove "binding" the rings.
The bottom piston is in decent shape also, best I can tell.
My questions, desire for opinions/advice, is about the rings themselves. I am pretty sure, although you can correct me if I am wrong, that the pistons themselves are good to go with a little clean up. There is no cracks, chunks missing, holes or anything like that wrong. Seeing how the rings are what keep in contact I would assume they are the critical point.
So as far as the rings go, what classifies them as being "unfit for service"? It there a way to put calipers on them and decide if they are too worn? There is no sign of any breakage or anything to that extent. In fact they look like they have only been in for a little while.
It almost looks like the motor had been rebuilt, then something got caught in the cylinder and made this happen. Or maybe because of all the sand I found in the exhaust cover(thats another subject), it over heated, which I know has happened sometime in the past because of the discoloration, and when it overheated it caused this damage to happen.
Either way, I need some advice from people that have seen and dealt with this before, and opinions on what to do. Also I will attach a picture of what looks like some molten aluminum on that middle cylinder, on the edge, in the water jacket. I can tell its aluminum because it is not magnetic.
Thanks guys! If you hold your mouse over the pictures it will tell you what piston it is and so on.
