I have a cable with a thread and nut down the engine end and the other is still in the control but I am not sure what the connector is between thread and the ball joint on the bottom port cover. Can someone direct me to a web picture or shop component of the setup? The clymers doesn't help me much.
Below are the throttle and gear shift linkages.
