My 50hp starts fine (starts right up) after it has been sitting for a while. in fact, I never have a problem starting it on muffs. However when i get it on the water and after I run it WOT (to go to my fishing hole) and try to start it back up after say 15 minutes or an hour or two, it is usually hard to start. Gas pours from thecarb when I lift the motor to drain it. If i wait 10 minutes or so after lifting it and draining gas from carb, it will start. Obviously it is flooding. Any ideas on what is causing this? fuel pump kit in order possibly? I just put new spark plugs in too, so it is sparking, they get saturated i suspect. Any insight is appreciated.
