My 1988 125 Force Engine will only start if I remove the white stop switch wire from the terminal bar on the engine block. I have already replaced the ignition switch and the stop switch lanyard. I have double checked the wiring at the ignition switch and it appears to be correct, what could be wrong? I'm ready to go fishing!
