Re: Force 125 Head Bolts Seized
Yeah I've been doin' the PB Blaster thing for 3 days now. I also tried heating it up with a propane torch hoping it will expand enough to allow the PB to penetrate a little deeper, but still no luck. I'm affraid of warping the Head but I may have to use a little more heat, IE: Oxy/Acet torch to heat up just around the bolt areas. And I guess at worst case scenario, I have a Vert. Mill in the shop and could knock off .005" to .010" to verify its flat. I haven't seen the underside of the head yet but I believe the Squintch Band is made by the gasket and not machined into the head so therefore won't hurt anything milling some material away. If any of you guys have any input to help me get through this the easiest way I sure would appreciate it.
Thanks for all your help, Joe.
