Re: Ignition Key/Tumbler 1966 45HP Chrysler
Thanks for the answer, I picked up the correct ignition and heres whats going on. I wired everything correctly as in by the book im using for engine, and by your answer, the switch must have power because the choke solenoid is working properly however the engine is now not turning over, this model is the magneto ignition, oh and the circuit breaker is functioning because with the ignition wired up i tried to start the motor by jumping from right side terminal of the starter solenoid to the yellow start wire on top and it tripped the breaker (resetting it by disconnecting battery makes the choke operate again) im bamboozled as to what could be wrong here, any input?
