1988 Force 85hp
I idled it 10 minutes yesterday off of muffs to get the engine up to temp and to check the water pressure gauge that I installed.
This morning, I found some oil residue on the lower unit below the plate. Does not smell like gear oil to me, also no smell of gas in that oil. Just smells like, well, oil.. very thick viscosity though.
Excuse the tape... I use that to better seal the muffs on the lower unit.
Here is the first picture...
It seems to be leaking from both sides, same bolt on each side! What might this be? Is it leaking from the bolt, or from that small hole next to it? I saw the posting on improper fuel mix maybe causing this.
I'm going to drain and replace the gear oil later today and look for water.
Thanks,
Frank
Thanks,
Frank
