I put a 1989 125hp Force motor on my 17' skeeter bass boat. I have the controls that came with it and I am trying to get it all hooked up but cannot get power to the motor and cannot figure out the problem. here are pictures to explain my issue. No power to tilt and trim or to starter. I have power to starter and tilt and trim when i bypass everything and touch battery the individual parts.
here is wiring pic at motor,
[/IMG]
I have my neg from battery connected here, circled in red,
[/IMG]
I had the positive from battery connected on the left side of the circled area, I dont know what this "block"is called.
[/IMG]
Here is a pick of the rest of the wiring. circled in red is a purple wire that is separated that I connected when attempting to get power, and a red wire with white stripe that has a connector on the end and a black wire with connector on the end, which I dont know where these two belong.
[/IMG]
Thank you for any help
