Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
What are the symptoms of a weak fuel pump?
  • What are the symptoms of a weak fuel pump?
    How do I tell if my fuel pump diaphragm needs to be replaced? Early 70's 55hp magneto ignition, single carb.
    If the pump is in good enough shape to start and idle smooth and run in the lower ranges fine but is not good enough for WOT running, how will it act? Would I expect it to just have a significant lack of power at WOT or should it be sputtering and missing?
    Re: What are the symptoms of a weak fuel pump?
    Just like a heart, a weak pump can't keep up.
    When goals have no clear focus, neither will the actions of the people trying to achieve them
    • #3
      If it is original replace it. The diaphragm is only about 5 bucks and it only takes about a half hour to do it.
      • #4
        I have no idea if it's original or not. I'm replacing it regardless, just trying to determine if a weak pump is causing my top end power loss problems or something else. It's the only thing I haven't been able to rule out yet but my thoughts are that a weak pump would just cause the carb bowl to be sucked dry at WOT and it would start sputtering. I don't have the typical starving symptoms, but acceleration just hits a brick wall above 3/4 throttle.
        BTW, where do you get one for $5 at, the cheapest I can find is like 17 bucks.
        • #5
          My next check would be timing.
          • #6
            Timing is correct, throttle sync is correct, all ignition components good, points gapped and sync'd properly, no bad wiring.
            • #7
              If everything is correct, maybe you are expecting too much out of the motor. If the RPM's are there, the load may be too heavy, the prop may be the wrong pitch. Sorry, I'm out of suggestions. Maybe Frank will chime in.
              Back to Top
