HI
I have owned three previous outboard engines (other manufacturers), all of which pumped water out the telltale when idling. This was both in the water or on the muffs.
My Force 120 hp on the other hand pumps no water when idling.
Is this common with the Force or do I need to replace my impeller.
The engine runs sweet and pumps from the telltale when running.
Any help will be appreciated.
Thanks
Thanks
