Where can I find a cut-away/section view of a 35 HP Chrysler showing exhaust and cooling water travel?
Otherwise my questions and interest are:
1. Will cooling water and ?some? exhaust mix at some point before exiting the cooling water?s port?
2. I know some or all exhaust is exiting the bottom of the leg but where does it come in w/o mess in leg?
3. Does external water or exhaust exist in the water pump area of the leg? I saw no sign of either in leg.
The attachment?s parts have not ever been cleaned but notice how clean they are and ?How In Years??
4. If water and exhaust are not there, what causes the water pump?s bolts to become a challenge to rem?
5. Did I read that water pump?s int. walls should be rubbed with bar soap when installing an impeller?
Thanks in advance for you help.
JOW
JOW
