hi knowledgeble folks
the only way to start this engine appears to be to have the fast idle lever hard on with choke. on starting the choke can be dropped but the engine always stalls unless the RPM kept high at ~ 5,000 RPM.
had it to the shop a couple of times but the problem not fixed.
seems a brutal way to start a cold engine
is this normal and if not what are the tweaks to look for ?
cheers
oldbones, melbourne, australia.
cheers
