1966 Chrysler 50hp
m# 50671 S# 5634
This came on the project boat i picked up and fired up on the second try after sitting for several years outside in the snow. But it has had some very poor repair work on it like clear silicone as gaskets and so on.
Ive searched the forum and all over the web and can't find much about this old motor. The manual is very basic but has helped some. I know they only made this style 50hp for one year but i am hoping that some of the part were used on several models and years that would cross over.
Below is a list that i need so far for the gearcase. BTW the water pick up on this one is above the prop right in front of the exhaust not in the leg like normal.
Water pump kit or
Impeller 47-F33065-2 maybe??
shift rod seal
bearing cage damaged-welder might be able to fix it
fuel pump gasket kit
voltage regulator/rectifier missing and wires are just loose from the stator.
m# 50671 S# 5634
Water pump kit or
shift rod seal
