Ok guys, BTW--it is a 1997 force 120hp motor
New Problem. As of a few months ago i replaced the water impeller, thermostat and gave the engine a tune-up with new plugs and everything.
the Boat usually has had no problems but i have only had it out about three times since all this took place.
Today I go out and a buddy of mine and I decide we want to troll the big motor instead of using the regular trolling motor to fish for Stripers today.
All was going well until i hear the alarm sound for an over heat on the motor? Strange --i said. As soon as I heard it I shut it off thinking i didnt want to cause any damage to the motor. We waited the alotted amount of time for this to cool down and restarted the motor and ran around the lake at full throttle no problems.
Again we go back to trolling at slow speeds and again we hear the alarm sound for over heat--this time i look back to make sure the motor's pee hole is exausting water and it is running just fine and peeing ????? weird?????
Again i shut it down and we wait. Again we make another run around the lake wide open with no problems and go back to trolling and this time we are able to troll the rest of the day with no problems???? really weird now--no more alarm ????
Can someone explain what is going on--i called my mechanic and he seems to think it might be a sensor going bad maybe??? or that there may be corrosion somwhere in the tube?
Could I have a faulty Brand new Thermostat--my mechanic said with almost 90% accuracy he doubts it would be a new thermostat that went bad --it just doesn't happen on those items
HELP me figure this out please
