Where can I get OEM part numbers for my Force 150
HawaiianHooker
I was trying to order parts from iboats here but they couldnt help me needed unless I had OEM part numbers???
Anyone know where I can get OEM part numbers for my '92 Force 150?
Thanks!
--Mike
roscoe
Re: Where can I get OEM part numbers for my Force 150
Please note, that 1992 is a very bad year for Force parts identification.
They used the old model number system, then half way thru the year switch to the new serial number system.
so there are 1992a models
1992b models
1992c models
then the serial number models starting with OE000001
To make it worse, they switched major components during 1992.
The fuel pump, oval 2 stage, to square.
And the entire ignition system was changed mid year.
Not that hard to do if you know what you are looking for, if you need help, just ask.
Strange that iboats doesn't use model numbers to cross reference like the rest of the industry.
http://www.dougrussell.com/partscatalog/collections/index.cfm?fuseaction=collectdetails&colid=06
http://www.mercruiserparts.com/selectModels3.asp?type_id=FORC
http://www.crowleymarine.com/parts.cfm
