85 hp force how to find serial number
harry1948
I have a low speed miss at high speed it goes all out. I need help on where the serial number is so i can down load a manaul
themichelob
Re: 85 hp force how to find serial number
harry1948--On my 85 Hp there is a metal plate inside the cowling right in front of and just below the carbs that has the mod and ser numbers. Regards, Mike
capri1600
My 1983 Force 85 has the data plate in the same place.
sho3boater
My '83 also has the plate right under the carb horn on the bottom cowl plate, this is inside the cowl. Tells RPM range also.
harry1948
thanks for all the help that where it was thanks again harry1948:)
pappy1958
For those who still can't find 'em, mine are on the transom support, left side on a tag.
