Hello to everyone,
First off i have ordered a manuel from ebay (seloc) on my motor so i can become more familiar with my motor. This is a new to me boat and I want to do most of the work on it myself. I have watched many videos on repairs and i think i am pretty handy to fix just about anything. My experience level as a mechanic is beginner level--but thats not to say i can't do it.
Secondly, i have orderd gear case oil, lubricants, the correct 4 spark plugs, I am wanting to order a water pump kit(or do i just need the impeller?) and thermostat as I dont know when the last time they were changed or even looked at. I think I am able to accomplish many of the minor items of a motor such as Carb, fuel pump, changing the lower units oil, spark plugs, etc....
Now as far as she runs now well I can say she runs pretty well at WOT and most of the time at idle speeds. But I do notice from time to time not often that the idle is just not right. Like the carbs need a slight adjustment or something. Sometimes when placing the motor into gear it will die. then I have to restart at 3/4 neutral throttle to get her reved back up and try to gear forward again. Something is just not right...I just can't place my finger on it. I have not attempted anything yet. I have ordered alot of things and wanted to know if I should do a re-build on carbs or simply make an adjustment and add spark plugs. I plan on doing a compression check as well.
Any Ideas why the motor dies when going into gear?
Thanks to all for any help as i start my project.
